12-24-2022 12:18 PM
12-24-2022 04:21 PM
@BKNS27 wrote:If it is the SIM PUK showing on your phone then contact a CS_Agent through SIMon Chatbot on the bottom of page or private message them on the envelope icon above.
But try 1234.
If you have a Samsung phone, it could be the PUK for the phone so contact Samsung Canada at 1-800-SAM-SUNG.
Please do not advise members to try 1234 as a PUK. A PUK wouldn't ever be 1234.
12-24-2022 01:03 PM - edited 12-24-2022 09:12 PM
12-24-2022 12:28 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is really SIM card PUK and If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
12-24-2022 12:19 PM
@Calexander2 , the pros will be here to answer shortly, I’m curious myself to learn this answer !
