Unable to send text can’t activate cell number on Imessage
Halfdan
Can’t send text and can’t activate cell number on imessage
2 REPLIES 2
funpig1
@Halfdan
Did you get your plan activated and is your service working properly? If not, you can message a customer service agent. A response may take a few hours or a few days depending on how busy they are. Good luck.
Sansan
@Halfdan  Have you gone into the iMessage settings and tried removing the iMessages from and  restart phone and registering? Also sign out of Apple ID and re-register.
