Problem to log in
framboiselev
Doesn't accept my new password... Looks like it doen't recognize my email...
hycm53
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login, so don't use mobile device to login.
Follow above method try login again.
If still doesn't work, chat with Simon for help, if Simon can’t help, he would let you submit a ticket.
https://www.publicmobile.ca/en/on/get-help
@framboiselev @You can try clearing your web browser cache / cookies and sign in incognito mode / private mode
@framboiselev if you have got the reset password email , then it did recognize your email
Try again using Incognito mode to request reset password and loginig in.
If that still does not work, then open ticket with PM support using Charbot and they will sort it out for you
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
