02-28-2023 12:53 PM
I put correct info in n still tells me wrong email or password!! What is going on. Just wanna talk with a PERSON to straightened this out!!
03-01-2023 10:26 AM
@Bundles - Have you ever created a My Accounts before on these accounts? If not, and you are a current customer (have been active within 90 days and have not ported out to another provider), you can submit a ticket here to: Create or forgot My Account email or password link
02-28-2023 01:47 PM
Clear cache
Clear cookies
Reboot device
Try different browser.
02-28-2023 12:56 PM
Just clear your cache on your browser first before login. There is a cache problem on the PM website.
02-28-2023 12:56 PM
HI@Bundles you tried to reset the password yet? Use the Reset password link there
or you can open a ticket with CS agent for help at : https://publicmobile.ca/chatbot.
First type Forgot Login,
02-28-2023 12:55 PM
@Bundles you can try again. Close the browser and try with Incognito mode
if that does not work,, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
