02-03-2024
01:16 AM
02-03-2024
11:46 AM
computergeek541
I have been locked out of my account since January 26, I had to create a new account just to post this. I have tried waiting for days to login, waited for days again to try the forgot password option. Nothing works and I keep getting a user locked out message. How do I log into my account? I have no data left and just want to add more
02-03-2024 11:49 AM
My service has not been working. It only works if I am connected to wifi. I have tried the app and the browser in incognito mode, the issue is the same with both, I am still locked out. I sent a PM to a CS agent a few hours ago. How long is the typical wait time for a response?
02-03-2024 10:34 AM
HI @Eleisha
but your service has been working?
are you using the browser or Public Mobile app? Try both. For borwser, try Incognito/private/secret mode on your browser. For app, try uninstall and reinstall the app
if same, please submit a ticket with CS Agent here:
02-03-2024 02:44 AM
Are you using the PM app? Try login to the app and click on Add-on.
If that fails, your only option is to contact a CS_Agent to help you login to purchase Add-on at:
02-03-2024 02:20 AM
Usually you can click on the option to reset password. But if it doesn't work you can send a message to customer service at the link below and ask them to help.
