Thursday
I have a locked my sim and it asks for PUK CODE however I cannot get into my original PM account as my email and PM account both have 2 step authentication that requires ,e receiving a text. It told ,e to open a new PM mobile account and request this info but I need it asap.
Thursday
My email has my ph as 2FA lol
Thursday
you can, but this is something PM support can help
And you can now login My Account using email to receive 2FA? if not, you will still need support to help you to update the new sim card number
Thursday
Can I just buy a new sim .?
Thursday
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier help unlocking it.
(Sorry, for this particular issue, PM support would not be able to help)
Thursday
@JuanP normally the code is 1234 unless you had changed it yourself.
Thursday
@JuanP, I think you will need to open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
