3 weeks ago
I have e-sim that was transferred from my old number. I cannot receive voicemail nor access voicemail. Play back of voicemail always says "you have no messages" but I know some people left messages
3 weeks ago
can you receive incoming call? problem like this can be because the port was not done
so, check to remove your old sim/esim. Then enable PM sim and set it as Primary. Reboot phone and Reset network settings.
First test incoming calls, then test voicemail
