Account Locked. Reset Password Failed
Quinshin
Hi there.
Hope you are well.
I need some urgent assistance with resetting my other account. I cannot sign in or reset my password.
Regards,
Quinshin
hi @Quinshin
not "Support"
PM support team is @CS_agent.  You can use this link to message them
Quinshin
@softech : Can you kindly tell me what the DL is for the support team? is the one that says Support when I search for the it?
Thanks again.
Quinshin
Quinshin
Yes it is separate but still it doesn't work
Quinshin
Hi. I tried the steps and issue is still there. I tried the private message link. It only leads to a page with the word private message. There is no field to write anything at all. Please kindly advise.
Regards,
Quinshin
Dunkman
@Quinshin
Does your other account have its own separate email address to login?
With public mobile, each PM phone number needs its own separate email address/account.
@Quinshin
did you try on both browser and app?
I suggest you to wait another hour and try again
  1. using the browser with Incognito mode
  2. Try again using the app.  If you have already installed the app, uninstall , reboot and reinstall.
    And remember to grant Location Permission to the app before trying to login
If issue persists, please message support for assistance
