List of phone calls
Katia8
Hello dear team,
I need to have a list with all my outgoing phonecalls from the last 6 months, is that possible? I need them to be able to appeal a case.  Thanks a lot!
7 REPLIES 7
Katia8
Hi HTideGnow, no it's not for a court/legal case. I will submit a ticket at that second link you provided!
@Katia8 keep us updated with what support says, but unless you have something serious, I doubt Support can provide you that
Katia8
Hi Halimacs, apologies for any confusion - it's not for a court/legal case. It's just to prove that I attempted to call a separate company between a specific time period because they are saying I did not do so. I will try to contact support.
Katia8
Hi Handy1, yes thank you. However, it only lets me see the past 90 days and I need my usage history from before that time. I will try contacting support directly.
HALIMACS
@Katia8
regrettably, only a court order for that information would compel public mobile to provide records further than the 90 days they routinely supply.
But it’s worth a shot – so definitely contact support as previously suggested.
@Katia8  You can check usage history in my account overview page at bottom of screen but you can ask support for it too
HI @Katia8   court case?
PM only provide 90 days usage
But if you have legal case, you can try to submit a ticket with them  at
