02-08-2022 07:54 PM
I just re activated my plan but nothing works. I tried shutting down my phone and everything else but still line is still cut.
02-08-2022 08:22 PM
you changed number right, can you check your new number in your account ?
02-08-2022 08:18 PM
HI @adamshaker What brand and model of phone do you have?
02-08-2022 08:18 PM
@adamshaker wrote:Just tried. Didn’t work. I really don’t understand what’s going on…../
@adamshaker - if all troubleshooting is failing, contact Customer Support to check on the activation. Two ways to contact them hereL https://www.publicmobile.ca/en/bc/get-help/articles/contact-an-agent
02-08-2022 08:16 PM
02-08-2022 08:12 PM
@adamshaker wrote:What do I do ???
HI @adamshaker you said it connects to the network, so, it shows Public Mobile on top ? and how many barrs of signal?
what is the brand and what is the model of your phone?
If it is an LG, you will need to perform a Network Reset , in some case , even a Factory Wipe.
Do you have a second phone to test the PM SIM
02-08-2022 08:11 PM
Try this. In self service choose lost/stolen. Suspend your service and then log out. Log back in after 1 minute and resume your service. Reboot your phone.
02-08-2022 08:10 PM
Doesn’t work either
02-08-2022 08:10 PM
What do I do ???
02-08-2022 08:05 PM
02-08-2022 08:04 PM
Active
02-08-2022 08:04 PM
log in to Self-Serve, your account Status ?
02-08-2022 08:03 PM
The network shows. I tried calling, texting and so on. Nothing works.
02-08-2022 08:03 PM
@adamshaker wrote:I just re activated my plan but nothing works. I tried shutting down my phone and everything else but still line is still cut.
@adamshaker if you activated with a new number services should be pretty much immediate.
Rare times it just take a little bit to getting going....
Try one or more of the below:
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Can you try the SIM into another phone to see if services work?
02-08-2022 08:02 PM
HI @adamshaker
First of all , do you see it connected to the PM network at all? It should show on top of the phone the network signal.
IF it connects, test outgoing calls first, then test incoming calls and then Mobile Data , and let us know if they work
If it does not connect at all, will be a problem with SIM provision. Please open ticket with PM Support
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
02-08-2022 08:02 PM
No messages. Yes I had available funds on my account and they got used. Phone unlocked, it used to work 1 month ago. I didn’t pay last month. Before everything worked.
02-08-2022 08:00 PM
But I didn’t port in
02-08-2022 08:00 PM
I changed my number
02-08-2022 07:56 PM
Hi @adamshaker
you getting new number or port old number to PM ?
02-08-2022 07:55 PM
Any messages on your phone? Can you confirm your cc was charged? Are you porting a number in? Is your phone unlocked?
