07-23-2026 09:34 AM
08-24-2026 10:02 AM
I just re-set network settings and the phone now shows connected to LTE instead of 5G and seems to work better. I’m now on data writing this message and it works fine. Wonder why because I thought being in 5G network should be better.
07-24-2026 09:21 PM
Check your account status. My payment didn’t go througg
07-24-2026 11:40 AM
Same
07-23-2026 11:07 AM
What is the make and model of your phone?
With the 3G shutdown, your phone must be VoLTE compatible on PM network so enter the IMEI of your phone to see if it is compatible.
Here is more information on VoLTE:
https://www.publicmobile.ca/en/get-help/articles/volte
If it is compatible, check for outages:
07-23-2026 10:25 AM - edited 07-23-2026 10:27 AM
It may not be your phone but a problem with the service . In my area recently have been experiencing the same and also total internet outages . My neighbour was considering going back to a landline but I explained to him that now - so called landlines — also rely on internet reception .
07-23-2026 10:03 AM
new or existing subscriber?
try Reboot your phone and reset network settings and test again
if same, tell me what device you have, and tell us if mobile data works
