08-30-2016 04:14 AM - edited 01-04-2022 03:09 PM
Service
07-06-2017 09:00 PM
@Ottawatech I suspect that @holhm22 probably resolved this about 8.5 months ago, around the time of the last activity on this thread. Just sayin'.
07-06-2017 05:41 PM
Any problems Msg me
09-14-2016 01:32 PM - edited 09-14-2016 01:32 PM
@holhm22 wrote:
I use a OnePlus One, and when I was still on Wind, it showed H+ when it was using HSPA+, never 4G.
@holhm22 you've said it yourself. Your phone shows H+ when on HSPA+ and LTE when on 4G LTE. You're already on 4G when it's showing you LTE.
09-13-2016 06:34 PM
Let me know.
09-13-2016 05:57 PM
08-31-2016 04:23 PM
08-31-2016 02:18 AM
08-30-2016 09:55 PM
This is incorrect. Android has different symbols in the status bar for LTE and 4G. My international Note 4 was able to show both 4G and LTE in the status bar. LTE showing when the connection was at its peak.
@OP what phone are you using?
08-30-2016 09:03 PM
And just to be super clear
There are different types of LTE as well
LTE Advanced is NOT the same thing as LTE
Even though phone shows same icons
eg the Apple iPhone 6S has a 300 Mbps compared to the iPhone SE which caps out at 150 Mbps
Heck even the Blackberry Priv has 450 Mbps (take that Apple!) as does the Galaxy S7
08-30-2016 08:57 PM
@pmobile the terms LTE & 4G are used (incorrectly) interchangeably
Same issue with 3G & 3.5G standerds
Lots of issues in how telecom industry advertises
08-30-2016 02:40 PM
08-30-2016 09:49 AM
4G = LTE on Android.
08-30-2016 08:55 AM
Sorry just to clarify, I mean interchangeably like you'll be on LTE but some SIMs or Phones show 4G instead but still mean LTE.
08-30-2016 08:54 AM
I could be wrong but aren't 4G and LTE used interchangeably? I know you mentioned that you're using the same phone so it is kind of strange but are you able to confirm you're getting LTE speeds or not?
08-30-2016 08:10 AM
My phone doesn't even have a 4G option ... LTE, 3G or 2G. If your phone is setup to LTE maybe the sat tower only has 4G. Have you tried rebooting the phone?
Maybe you stepped out of range of some satelites? does it happen everywhere?
08-30-2016 05:34 AM
If you have an Android device you can switch to LTE in your settings menu. Maybe others can contribute instructions for the fruit phones (blackberry, apple)?
Apart from the cellular network icon at the top right of your screen, you can confirm which network you're connected to by navigating to your device's' Settings' menu:
Settings>System>About Phone>Status>Sim Status and under 'Cellular Network Type' you should see 'LTE, but if you don't follow these instructions:
Navigate to Settings>Wireless & Networks >(More)>Cellular Networks>Preferred Network Type and select 'LTE'.
If your phone doesn't switch to LTE right away - indicated by 'LTE' above the vertical cellular signal bars icon at the top right of your screen- reboot your device and you should be good.
If 'LTE' was already selected as your 'Preferred Network Type' but you weren't connected to the LTE network, try selecting '3G', exit the settings menu, go back into the settings menu and select LTE' . If you don't see a switch right away to the 'LTE' network try rebooting your device.
Hope this helps...
