02-07-2018 02:09 AM - edited 01-04-2022 03:28 PM
Good evening Community,
You can call me Koal. I am new to Public Mobile, and I'm in need of some assistance. Your help is GREATLY appreciated. I just purchased the unlocked Sony Xperia XA1 Plus smartphone, and transfered my PM sim card from my older device, a BLU Vivo 5 into my new device. I am on a Canada Wide Unlimited talk, and international Text + 3GB of 4G LTE data plan. My services worked perfectly fine with my older phone, and even with an alternative Sony Xperia of a different model; before purchasing this recent Xperia XA1 Plus device. Calls, text messaging, wifi works perfectly fine on my new phone. Data however just will not work. I checked the Bandwidths specs and it is as follows for this Xperia XA1 Plus model: LTE-A Cat 6 (300/50 Mbit/s), HSDPA+ (4G) 42.2 Mbit/s, HSUPA 5.76 Mbit/s. Bandwidths: B1, B2, B3, B5, B7, B8, B20.
I have gone into the mobile data settings; then discovered the network; and selected 4G LTE for PM and to no avail... I have turned on LTE services, nothing. Not even the 3G data will work. Please help, I will appreciate the assitance if anyone is still awake
02-08-2018 11:38 AM
@will13am oops. For the record, while I'm in @stonechucker's camp of not being a football fan, no offense was intended. Apparently I have faulty RAM and should check myself into the nearest repair facility immediately.
02-08-2018 06:42 AM
wrote:
wrote:
wrote:
@srlawrenwrote:
@makkahn28wrote:Hi. Here's something else as well, IF you wish to tether:
APN Tethering Settings:
Name: Tethered Mobile Internet
I enlarged the word dun, THIS is key IF you wish to Tether
@makkahn28 as @NDesai told you on your other thread, this is not needed.
Argh @srlawren, how can you mistaken a Patriots fan from a Patriots hater?
@will13am For me, football, NFL specificity, doesn’t matter.
@stonechucker, it was just a friendly jab at @srlawren. He should be able to see that the Patriots are nowhere to be found in my avatar.
02-08-2018 01:05 AM
02-07-2018 08:38 PM
02-07-2018 08:17 PM
02-07-2018 08:06 PM - edited 02-08-2018 11:36 AM
@makkahn28 as @NDesai [edit:oops!] @will13am told you on your other thread, this is not needed.
02-07-2018 05:22 PM
if changing the APN doesn't work, you may have to do a quick reset of your phone.
02-07-2018 09:12 AM
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
02-07-2018 02:34 AM
Omg, I could kiss you LOL. I felt disappointed, thinking I may have to return this phone. Thank you so, so much, it worked!
02-07-2018 02:20 AM - edited 02-07-2018 02:21 AM
Good evening!
I think you need to change the Apn settings on your phone in order for your data to work. Please click the link below and follow the instructions.
Good luck!
