02-07-2018 09:17 AM - edited 01-04-2022 03:28 PM
You know how PPL have had issues with how to connect, and such, I find that the TETHER info omitted, and that's a shame
HERE is the Tethering INFO:
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
I enlarged and Bold the wor dun so that PPL know exactly
02-07-2018 08:30 PM
dun is not needed in APN type. Tethering works fine without it.
02-07-2018 11:18 AM
@makkahn28, I am sure I have mentioned this before and likely more than once. The tethering APN is totally redundant and perhaps should be depredated. The sp.mb.com APN does not block tethering and works fine. For some android devices, adding dun to the APN type field may be required. I always tell people to not leave the APN type field empty.
