Just converted from e sim to physical
MS24
Hi community, I just changed from Esim to physical but I'm still receiving the SOS error.  I've messed with my settings in Cellular data ensuring I'm using the physyical sim but nothings changed.  What's my next step?
@MS24  Can you try the. SIM card in another phone and test it again? If you haven’t already trying to reset network settings . Worst case just engage support and they can re provision the sim for you in their end
send  a  private message   To CS_Agent
hairbag1
@MS24
so did you download the app to your cell and change sim card ?
@MS24
Did you go to My Account's Profile page or Account page on the app to update the sim card number?
If you already did that, disable, but not delete, the esim first, and Reboot the phone once more, click Reset Network Settings
If you have not update the sim card number yet, please do so
 Or if you cannot login to update sim card number, please message CS agent
Private message CS Agent at:
