10-15-2017 02:07 PM - edited 01-04-2022 02:46 PM
Using a ZTE Axon 7. It's duo sim, and my Freedom mobile SIM is work on it right now.
New activation, getting no bars on my Public Mobile sim card
Tried manually doing APN, restart the phone, system wipe the phone, tried different sim card slots.
inbound, outbound, data, even 611 is not working.
Is this a faulty sim card?
10-16-2017 11:21 AM
@pakmode wrote:Let us know how the phone is.
This is the $149 phone everybody on RFD was talking about right?
That and the $39 USD Moto E4 have been all the rage lately for cheaper phone options.
Almost, the phone for $149 is the Axon 7 mini. Which isn't spec'd quite as well as the regular.
10-16-2017 11:08 AM
10-15-2017 02:45 PM - edited 10-15-2017 02:48 PM
Glad it all worked out @Peterium. Welcome to PM!!
Another example of how quick and responsive the Moderator Team is!!
10-15-2017 02:43 PM
Turns out per moderator there was a glitch in activation. They've submitted a ticket for back end issue. Thanks for all your help guys!
10-15-2017 02:40 PM
Hi guys,
Thanks for the quick reply.
Tried working with only the Public Mobile sim card on both slots.
Tried manually doing APN per instruction.
New Public Mobile number
My phone is a ZTE 2017U according to the about phone. Bought it on Newegg.ca and they do have a Canadian HQ. It's worked on Rogers and Freedom Mobile before.
10-15-2017 02:33 PM
I suggest for troubleshooting, try with only the public mobile SIM card installed. Add the second SIM card after you get this service working.
10-15-2017 02:32 PM
10-15-2017 02:29 PM
Was the number ported over, or is this a new number? Sometimes porting a number can take a while; how long has it been like this?
10-15-2017 02:26 PM
Checked your phone on willmyphonework.net and I got this result, so it isn't a network issue if you are using either of the two sub-brands listed:
Just confirm the sub-brand to be sure we're talking about the right phone.
As your account is showing "active" in self-serve, this pretty much leaves you with a potential SIM card issue. Can you try the SIM in another phone to be sure.
Also, double check your APN settings are as follows:Make sure your APN settings are as follows:
_______________________________________________________________________
Set up your APN
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
________________________________________________________________________
Let us know if this helps get things working by posting a reply.
10-15-2017 02:07 PM
By the way, I checked and account status is active for public mobile.
