11-08-2023
04:28 PM
11-08-2023
04:30 PM
computergeek541
Hi there,
My wife and I both ported our numbers to Public. On my end, no issues whatsoever.
However, my wife's phone after successfully porting, has not received SMS or calls from non-iphones and landlines.
We have followed every single piece of advice in regards to reseting Network settings, SIM, airplane mode, and numerous other attempts at solving.
We have come to the conclusion (and others in forums) that this is an issue with our provider (Public).
The fact that Public Mobile has delegated customer service to a forum and unhelpful chatbots has made me regret switching over to begin with.
Now for my question, for the love of everything that is good and true:
Is there a human that I can speak to at Public Mobile before I cancel our subscriptions?
Has anyone experienced this before and solved this?
Phone: iPhone 15
SIM (not eSim)
11-09-2023 11:06 AM
@MBert93 There is a phone number for porting issues, just that we didn't know it was a porting issue until now. Check your community inbox in a few minutes and I will private message you the number to call.
11-09-2023 10:46 AM
So the issue was porting with the number.
Unfortunately we do not have the old sim card. After being on hold for a good bit of time with my old provider, they sent an authorization for 24 hours.
Now waiting on Public Mobile to confirm that. Less than 12 hours before they fix the problem.
Again, this would be way easier if I could have just called someone to check an authorization request on an account and just fix it, rather than send an email and hope for the best.
11-08-2023 11:17 PM - edited 11-08-2023 11:19 PM
yes this is a common issue with activations and the transfer confirmation text. contact customer support and ask them to reprovision/reset the network on their end.
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
11-08-2023 06:28 PM
Yes, they were
*On and off and on
11-08-2023 05:16 PM
@MBert93 Earlier you wrote "SMS Options have been turned on and off.". Can you confirm that afterwards you turned SMS back on again?
11-08-2023 04:51 PM
Yes. We ported / transfered the SMS at initial switch
11-08-2023 04:40 PM
11-08-2023 04:39 PM
@MBert93 - we are not agents here, just customers like you as mentioned.
This could just be an account provisioning issue, not a phone or SIM card issue. So first try the sim card in another phone, and if it doesn't work submit a ticket to CS_Agent as per #2 step above.
11-08-2023 04:38 PM
We coordinated with a friend to call her.
The number went straight to voicemail.
11-08-2023 04:36 PM
Hi @esjliv
Its a brand new phone from the box.
We are going to try her SIM in a different phone and report what happens.
We have together tried both those troubleshoots.
Can an agent pull up her SIM, or send a new one?
11-08-2023 04:34 PM
@MBert93 does your wife have a 'new to her phone'?
Deregister the old number on the iphone: https://selfsolve.apple.com/deregister-imessage/
Set up her new phone number On your iPhone:
Try to perform the following steps to try and fix the issue:
11-08-2023 04:33 PM
@MBert93 wrote:SMS Options have been turned on and off.
This is also happening with not receiving calls from not IOS devices.
A network issue certaintly is possible at some level, but that wouldn't affect communications only from others not using iPhone devices.
11-08-2023 04:32 PM
@MBert93 - can you try your wife's sim card in your phone and see if texts and calls work?
There is no phone number to talk to support here. And in this community we are all customers/members just like you.
Methods to contact Public Mobile Customer Support (CSA) below:
1-Normally Faster - use this link to: Get Help With Public Mobile Chatbot], also found in various places in Public webpages, and bottom right corner of the page (See the Chat Bubble),
BUT above process has been temperamental, so see below .... #2
2-, go to your ENVELOPE at the top right of your Community Account which is where your Inbox and Sent messages are. Select the orange/peach color box with the pencil inside it to start a new message. Type CS_Agent in the SEND TO box. This will create a private message to Public Mobile Customer Support.
11-08-2023 04:31 PM
11-08-2023 04:30 PM - edited 11-08-2023 04:31 PM
I can't think of any option that would cause non-iPhone calls not to come in. However, for messages, the SMS option needs to be enabble receive text messages.
