09-05-2022 12:56 PM
Hello,
I have two numbers that are not working for text and call for approx. 3 months even though the plan said I should be able to text and call. I would also like to request a rebate for these 3 months as my service was not working those 3 months and I am still paying for the plan with no service.
Any help to this would be appreciated.
Thank you.
09-05-2022 01:11 PM
Log in to your account using Incognito mode. Is the plan still showing as Active ?
Will your phone ring if someone calls your number ?
I'm sure you've already tried this but...turn phone off for a few minutes...then restart.
Let us know when you get it sorted.
09-05-2022 01:09 PM
Wow that a long time to wait to bring this to PM attention.
PM would have looked into you issue and have it corrected when you noticed no service.
PM is a prepaid service so not sure if they will refund for non-service but worth a try.
You can contact them by private message on the envelope icon above or create a ticket through SIMon Chatbot below.
09-05-2022 01:02 PM
Can you login to the accounts? Do they show as active? What make and model of phone are these phones (or if dual-sim which make and model).
Have you only been here 3 months? Is it all texting both in and out? Calls both in and out? Does your data work when not on wifi?
When was the last time you paid?
09-05-2022 12:57 PM
@farasatkhan hi why did you wait so long?
you need to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
