Issue after porting number
Harryv
I ported a number to public mobile.  All appears to work well other than that I am not receiving the verification text from public mobile  I verifies my email which works but then it sends a text which never arrives.  That means I cannot get into the account
8 REPLIES 8
CSA_PM
Customer Support Agent
Hi
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents .  The agent will continue assisting them directly.
hi @Harryv
maybe ask PM support to check
 you can submit  ticket by direct message:
@Harryv
I find there is a glitch sometimes with the 2FA code arrive late or didn’t arrive.
Reboot your phone by powering off then back on and click on Resend Code/Didn’t Receive Code.
Harryv
yes  can receive all incoming texts and calls.
I did reply yes.  The port worked.  I verified with the old carrier.
I cannot login until I get the text verification message.  which does not arrive
Harryv
I can receive all texts, data and make calls.  I do not reive the text from Public mobile when logging in
Chalupa_Batman
Hello @Harryv
If you have it being sent to your email and it's not arriving, please contact a CS Agent to combined the two together.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
hi @Harryv
can you receive inbound calls? sound like the port is not done
before the port is done, you can make calls and send text but not receive
Dunkman
@Harryv
More details would be helpful.
What about incoming calls?  incoming texts?
Did you answer "yes" to your previous carrier's port request text?
