Turn off my voicemail.
MapleLad
Please, turn of my voicemail
Ty.
hi @MapleLad
best to use Extended Absence trick
  • dial into your voicemail and log in with your PIN.
  • In the main menu, press 3 (manage greetings),
  • then 4 (manage extended absence greeting),
  • then 4 to turn off your extended absence greeting
Chalupa_Batman
Ty.
Public Mobile is a self serve service. Nobody from PM here.
Try this.
To set, dial: *004*8080000000#
To reset to default, dial: #004#
@MapleLad
PM does not have formal way to turn off voicemail, but here is the workaround
To "disable" voicemail, dial: *004*8080000000# on your phone
Then all calls will ring forever or get a fast busy tone instead of forwarded to the voicemail.
To reset it back to defaults, dial ##004#
