02-01-2024 09:46 PM
Whenever I try to login it doesn't recognize my last password. It either locks me out or I have to set up new password. My passwords are safed with goggle so they work the first time but the next time login it locks me out or I have to change again. I only get one try before it locks me out. Is anyone else having issues like this?
02-02-2024 12:00 AM
Eversafe ID doesn't respond well if you use autofill your email and password.
You may have to enter both manually and it will show checkmark to the right before trying to login.
02-01-2024 09:48 PM
HI @Jeanneb2023
try using Incognito/private/secret mode on your browser to login
if you have not use Public Mobile app yet, try there
Or next time, reset password, but do not use login with new password yet. Wait a bit before login with the new password, maybe 30 mins
