07-14-2023
12:54 AM
07-14-2023
02:00 AM
computergeek541
I am using a Esim at the moment, is it possible to switch to a physical sim without losing service while the physical sim is being delivered?
08-30-2023 10:42 PM
When you switched, were you able to keep the same phone number?
08-30-2023 10:36 PM
When you switched from esim to physical sim, were you able to keep the same number?
07-14-2023 01:08 AM - edited 07-14-2023 01:09 AM
I switched from an e-SIM to a Physical SIM Card on one of my Public Mobile Accounts last week and as soon as I Updated the SIM Card my e-SIM became unregistered and I had to manually delete it from Settings on my phone.
The new SIM Card began working immediately after updating in My Account Settings.
07-14-2023 01:05 AM - edited 07-14-2023 01:10 AM
Updated: Do not switch to the Phsycial SIM until it has arrived, stay on your current e-SIM.
e-SIM is only available for new Activations, therefore if you switch off it to a Physical SIM you won't be able to use e-SIM on your existing Account again until it is introduced for everyone. - Likely in September as the iPhone 15 will likely be fully e-SIM in Canada, with the S24 following sometime around February 2024.
