Cant access my public mobile account
cpetitclerc69
My iphone 12 bit the dust. motherboard is shot. It has a public mobile esim installed. I can't access my email because it wants to verify me via text and I can't access my Public mobile because it wants to verify me through my email It's a continious loop with no possible solution. Long story short I cant access my email, text or calls any more.
I bought a new phone and public mobile pysical sim. Not I am trying to transfer my old number to the new account and it says the number is not a valid Canadian number. I have been using that Canadian (Alberta) number for 10 years.  How do I transfer my old number to the new account and new physical SIM?
@cpetitclerc69 wrote:
OK, I had to create this new account just to message Public Mobile.
HI @cpetitclerc69
unforuately, bcause of the design of the system, yes, you need this new temp account just to message support agent
@cpetitclerc69  It happens they usually reply with in 1-2 hours sometimes longer
cpetitclerc69
@cpetitclerc69
Download the PM app on your new phone then to Account tab>Change Your SIM Card and enter the SIM card number to transfer your account to the new SIM.
@cpetitclerc69  No worries PM can sim swap  the number for you and you can keep same phone number and plan
send  a  private message   To CS_Agent
HI @cpetitclerc69
you need to ask PM support to help for the sim swap.. Just message them here
