2 weeks ago
I don't have another phone to scan a qr code, let alone know how to do so.
So, is there a manual way, with a link, to set up the sim card?
Thank you for any help.
2 weeks ago
hi @Garnabby yes, if you want eSIM, install the app on the phone you want the esim there
2 weeks ago
On second thought, I better move slowly with this thing, order only the sim card.
2 weeks ago
Do I "use Public Mobile App and the app will install everything for you" with the phone that I want to use with PM?
2 weeks ago
Okay, I will jump in with the $15 plan, and, then, try to figure things out from there.
2 weeks ago - last edited 2 weeks ago by computergeek541
Acaltel Onetouch
Model A392A
2 weeks ago
If it is a 2G and 3G phone. You should consider get a new phone soon before 3G will be decommissioned in 2025.
I would suggest the Samsung A03S from Staples or Moto G Play from Costco. Both are under $150.
2 weeks ago
I think public mobile is sending QT in the activation emails, so, open the email in your computer, and scan the QR code using your phone
2 weeks ago
do a old style flip phone is ok?
something like this?
2 weeks ago
@BKNS27Thanks.
About six years ago, my partner used an Alcatel Onetouch phone on PM. I'm not sure that it's a 2 or 3 G phone. I still have that phone, but, I, likely, will have to buy a new one. Something cheap to get by for simple phone calls.
I'm a Luddite when it comes to this stuff, but, patient enough to work through it.
2 weeks ago
hi @Garnabby
only two ways to install,
1. use QR code as you said
2. use Public Mobile App and the app will install everything for you
Yes, for some carriers, you might be able to manually add it, but not with Public Mobile
Please note you need to activate a SIM on the PM app on your phone.
The QR code is for activating an eSIM if your phone is eSIM compatible on newer phones.
What is the make and model of your phone?
