Is a call from Ontario to Quebec included in $15. plan registered in Quebec with unlimited canada ca
Gemmett
Hi @Gemmett   If you login to My Account and see you have Canada-Wide calling, then it is free
Most plans are Canada-Wide calling.  Last year, PM offered Provincial-Wide calling for a very brief time, and some old grandfathered plans might be Provincial calling only
LegusY
Check the name of your plan, and I'm pretty certain its one of the Canada-wide plans. If you're having a Canada-wide plan, you can call anywhere within the country. And don't worry PM doesn't let you do something that can result in an overcharge on your bill, if your plan allows you to call cross province, your phone will be able to do it. If its not included, your call will not go through. Hope this helps!
darlicious
@Gemmett
Yes. Unless you have an older legacy plan with provincial calling only. Then or if you have consumed your 100 outgoing minutes you can then choose to purchase the $5/500min add on (Add funds first then choose, confirm and submit your payment.) Or download fongo or textnow to make free calls on wifi or mobile data.
Meow
Yes, if your Plan is Canada wide then you can call from any province to any other even though you are not in your 'home' province.
RossN
@Gemmett yes you can call up to your 100 minute allotment you can also buy a 5 dollar 500 minute add on  in case you go over
