05-12-2022 07:04 PM
Hi, short of purchasing a new sim card to try, does anyone know if Public Mobile supports service on
Samsung Galaxy A70 and Samsung Galaxy A50?
I don't see them listed, and would love to add some family members to the service. Appreciate any insight, thank you.
05-12-2022 09:56 PM
You should be golden with the only exception being if they are blacklisted. Even international models shouldn't hit a snag
05-12-2022 07:54 PM
As long as they are bought new or from reputable seller second hand and are not blackisted they will work. Canadian version 100%. International version most likely.
If you have service with PM AND have both phones in hand, just pop SIM and test them. Simplest way to confirm.
05-12-2022 07:14 PM - edited 05-12-2022 07:15 PM
@Nic_Nic if you have a North American version, it will work without issue
International version will likely work, too but might not work as good as they might not have all the required bands. My friend have a A70 from Asia, dual SIM and he has some connection issue sometimes, and definitely does not work well when going to US (for roaming)
05-12-2022 07:05 PM
If they were bought in Canada from a reputable retailer absolutely yes.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-12-2022 07:05 PM - edited 05-12-2022 07:07 PM
