11-23-2016 06:16 PM - edited 01-05-2022 12:52 AM
11-23-2016 10:06 PM
I know of someone who had a simillar issue and that root cause of it was a defective sim card.
Try a new sim card.
11-23-2016 09:23 PM - edited 11-23-2016 09:25 PM
You already did this? Settings --> General --> Reset --> Reset Network Settings
Did you reboot?
If that doesn't work then perhaps a hard reset might be in order.
11-23-2016 08:27 PM
Maybe something helpful here:
11-23-2016 06:34 PM - edited 11-23-2016 06:36 PM
Try a hard reset.... (Might be an easy fix). Worked for some.
With the new operating systems (ios), a lot of those settings aren't accessible anymore.
Hope she works out for you.
11-23-2016 06:21 PM
