Invalid phone number
12-14-2023
08:46 PM
12-14-2023
09:12 PM
computergeek541
Long story trying to get wife's SIM card activated - for whatever reason at step 5 of the process it says SIM card is already in use and will not let her continue to put her phone number in (coming over from Telus). Everytime she logs into the app it takes her right to activate SIM card and no other options.
We bought a new SIM card in hopes that would work but then it says phone number is invalid!!!
Any suggestions- moderators can't help me help her for security reasons but she can't get to support on her app or website as it ALWAYS tells her to activate SIM.
Service
12-14-2023 11:09 PM
@Danny14 the error about invalid number you got now is because when she activated earlier when getting the sim card error, the porting request was already submitted
You need agent to update the sim card number for you and either release the earlier porting request or put in the porting request for you. Again, you need to open ticket with them by direct message using my link above
12-14-2023 11:06 PM
Yes using app to activate. No when she was activating the SIM card the first time, it said SIM card already in use - think maybe she switched the SIM card from Telus to PM before she should have (maybe that caused issues?). Anyways it's stuck on activate SIM card and just says already in use.
Bought new SIM card tried it then the invalid phone number message comes up. Can PM get our new card to work with her old number?
12-14-2023 11:03 PM
@Danny14 You can submit ticket using this direct link
send a private message To CS_Agents
12-14-2023 11:01 PM
@Danny14 have you message agent yet?
12-14-2023 10:57 PM
Trying to get her account from being stuck on activation page to contact support through her account. Haven't been able to yet
12-14-2023 09:07 PM
HI @Danny14
you might need PM agent to help to switch to the new sim card and help to complete the activation, please submit a ticket with CS Agent here:
12-14-2023 08:59 PM
@Danny14 did you let support know you have a new SIM card ? Can they not SIM card swap the number for you . So you can finish the activation
12-14-2023 08:53 PM
Did it twice, didnt work
12-14-2023 08:52 PM
@Danny14 Try to un install the app and re instal it see if that helps .
