Invalid SIM
KaiSchell
When I put the PM SIM card in the phone I want to use it comes up as an invalid SIM.  I have put that same SIM in other phones with no issues.  The phone I want to use also does not allow me to input the unlock PIN.  I have contacted the former carrier to get the phone unlocked, which they say it has been.  Any help would be appreciated.
9 REPLIES 9
Meow
It looks like your phone is locked to particular provider.
Did you Ever use your mobile phone as an active phone? And if yes, who was provider?
@KaiSchell
This is not an SIM issue but is locked by Samsung so call the number supplied by @softech .
This is a common issue with Samsung phones.
pkaraa
Try clearing cache in Settings > Storage > Internal Storage > Cached Data
VIP_Tech
Hi @KaiSchell
entering *#06# on your devices to get IMEI number to Check the Status of Your Device in Canada
@KaiSchell   Let me know how it turns out after you call Samsung (1-800-726-7864) .  People called before and they can provide either the Samsung master lock or the unlock code no problem
KaiSchell
I have inserted an active SIM card from another carrier and the phone gives me the same option.
SIM network unlock PIN screen pops up, but I cannot advance from there, even after pressing the unlock button it does not advance to an area where I can type in the unlock PIN.
@KaiSchell   Try to call Samsung, it might be a Samsung master lock it is asking for ..
Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
KaiSchell
I have put non-PM SIM card into the phone, it comes up with the same issue, "Invalid SIM card Network locked SIM card inserted"
This is on a Samsung Galaxy S9+
@KaiSchell   if you  put your PM SIM into other phone and it has no issue, then it is a device issue
did you try to put another , non-PM sim into this phone?  does it give the same error?
What EXACT error message you got on the screen ?
and what brand/model is the phone?
