3 hours ago
3 hours ago
Plus $$$$ for using their network!
3 hours ago
That is not going to happen. Easier to just purchase a local SIM where you are.
3 hours ago
This is NOT as easy as you think. This is not just to add new add-on.
PM or Telus has to make an agreement with foreign mobile companies which is not that simple...
3 hours ago
airlo is about the best option for travel sim. Get a data only sim and install TextNow to your cell. It uses your data or free local wifi to call/text to most any Cdn and US numbers.
3 hours ago
HI @DanDme
there are a lot behind the scene need to be done to add roaming to other countries. I don't think you will see it anytime soon. But you can still ask PM via the proper channel, submit a ticket with them and ask.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
