11-23-2018 12:39 AM - edited 01-05-2022 02:34 AM
My monthly plan only got 50 minutes canada wild talk and I add on the $15 international longD. If I made long distance phone call, would it cost my 100 canada-wild minutes?
11-28-2018 07:22 AM
11-26-2018 02:49 PM
@srlawren wrote:@Luddite I'm still adjusting to my new pair of eyeglasses, but aren't all of the options in that chart for unlimited talk rather than 100 mins? Or am I missing something....?
Correct. Your eyesight is fine. 😎
11-26-2018 02:32 PM
11-26-2018 02:21 PM
@srlawren You're not old enough to remember. ![]()
11-23-2018 12:14 PM
@Anonymous wrote:100 minutes?! Is this some old legacy plan?
@helen_llw33 I'm also curious about this--what exact plan are you on? I'm not familiar with all of the legacy plans, but I'm familiar with pretty much every plan offered from fall of 2015 though today and I don't recall any that included 100 mins of canada-wide talk. In fact, other than the $10/50/50 plan--which includes 50 mins, not 100--all plans I'm aware of since late 2015 at last have either had unlimited calling (prov-wide/canada-wide/canada+us-wide) or no calling at all.
11-23-2018 12:59 AM - edited 11-23-2018 01:07 AM
@helen_llw33 wrote:My monthly plan only got 100 minutes canada wild talk and I add on the $15 international longD. If I made long distance phone call, would it cost my 100 canada-wild minutes?
@helen_llw33If your plan includes canada wide 100 minutes and the number you are dialing is in canada it will use your canada-wide base plan talk 100 mins first then add-on after.
If the number is not included in your base minute plan (not canadian number) it will use add-on international, once those are gone, it will not use your canada-wide and the call will fail to go through
11-23-2018 12:42 AM
The $15 minutes would be used when you run out of plan minutes or call an international location.
