08-02-2017 08:02 PM - edited 01-05-2022 02:34 AM
Hello all,
It seems I somehow used up all my data super quickly, so I added on 200MB and it seems to be gone now too. When I go to Data and Add-On Usage, there is no information there. Is anyone else having this problem? And is there another way to find total data usage?
Thanks!
08-02-2017 08:46 PM
Thank you so much for your response!
08-02-2017 08:26 PM - edited 08-02-2017 08:28 PM
@cambria wrote:Hello all,
Thanks!
Correct. No data add-ons showing means data has all been used.
If you have an iPhone be sure WiFi assist is off, otherwise cellular data can be used even while on wifi. Streaming videos and app updates often are data hogs.
08-02-2017 08:13 PM
Send a PM to a moderator with your phone number, email address and a brief explanation of what's happening or not happening and they will sort you out. 🙂
