SIM card Slovenia and Croatia
Karen1
I will be doing a 15 day bike trip through Slovenia and Croatia in September.  The area covered will be urban and rural.  Does anyone have experience with SIM cards in these two countries?  I am looking for phone, text and data capability.
9 REPLIES 9
Acekiller
the other option is freedompop
Karen1
An unlocked IPhone 6
Karen1
Ah thanks for the screenshot.  I was obviously looking at the wrong page - I was looking at unlimited data.  I will have a second look
koimr1
@Karen1 wrote:
Thanks for the information.  I had a look at Knowroaming.  It looks great, but unfortunately is not available in Slovenia.  Good to know for another trip though.
Actually, if you go here Slovenia is on the supported list:
and
You mentioned you use WhatsApp, this might be of interest to you then (WhatsApp usage is free with KnowRoaming):
@Karen1
What phone are you planning on using by the way? Is it already unlocked?
Karen1
Karen1
Thanks I will look at your links.  I have no experience with SIM cards in foreign countries as I usually try to get by with wifi, whatsapp, etc.
sheytoon
I don't have personal experience, but I usually find a list of the operators and browse for their sites before I go on a trip. Using Google Translate, you should be able to find out their pricing.
I usually pick the larger operators because their coverage is generally better. Here are the oeprators in order from largest to smallest.
Croatia:
Hrvatski Telekom
VIP
Tele2
Slovenia:
Telekom Slovenije
A1
Telemach
T-2
https://en.wikipedia.org/wiki/List_of_mobile_network_operators_of_Europe#Croatia
https://en.wikipedia.org/wiki/List_of_mobile_network_operators_of_Europe#Slovenia
Have fun! Sounds like a great trip!
koimr1
I just came back from Europe and although I wasn't in Slovenia nor Croatia I got pretty close (Austria and Hungary).
I used a KnowRoaming SIM and had no issues with data/voice/text almost anywhere I went, including some locations in the Alps.
Because of my travel arrangements I needed to provide an Austrian number before I left Canada so that's why I went with KnowRoaming.
If you don't need the same then I would suggest getting a SIM card once you're there - much cheaper and better rates (in fact you might be shocked at how much we pay for regular service here in Canada as opposed to Europe).
While I was over there I could probably get a SIM card from various providers on almost every city block and definitely in every train station/airport.
