International calls
upuli94
I have enabled the calls to UK paying $15 but it doesn't allow me to make the call. I dialed the number correctly. It should be dialed as 011 44 (0) 22 xxxx xxxx according to public mobile. Still, they do not allow me to connect. This is a very important call I have to make.
Please help me to resolve this issue.
7 REPLIES 7
upuli94
Thanks everyone! You had been a great help to me. I removed that zero after the country code and dialed. Then it worked 😊
dent007
hope this helps:
when i call lancashire i phone 01144151XXXXXXX
pkaraa
@Anonymous wrote:
 @pkaraa : lol welcome to the new site. If you see a nasty red box or even wonder if it posted then open another tab and check if it did. Happens to me on occasion.
happened couple of times already
@upuli94
How to call UK from Canada,
  • EXAMPLE: 01144xxxxxxxxxx
pkaraa
Can you try after dropping the (0) between 44 and 22.
Another way try with + instead of 011 so start +44 ...
 @upuli94 : Drop that (0) and try.
