01-10-2022 06:28 PM
My wife and I have been advised that our plan is expired even though we are on autopay. I'm trying to buy US roaming add-ons and have added funds to our accounts but still unable to buy them. What's up with that?
01-10-2022 08:29 PM
Log back in tomorrow to check if your plan renewal date is tonight.
If your plan shows suspended and it is not even your renewal date then check if you have service and self serve shows Reactivate link.
If everything is good and there is no service and no reactivate link then shoot a direct msg to CS_agent to check on the backend.
01-10-2022 06:49 PM
Is your renewal tonight? Or have your services been suspended? Call 611 and check your account status. You should still be able to purchase US roaming add ons either thru 611 if you know your 4 digit account pin # or thru self serve as long as you still have working services.
01-10-2022 06:36 PM
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
go sign in to Self-Serve, to review your account,
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
when you visit U.S. then Purchase it,
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
Follow these steps:
after purchase successful you have to do Rebooting your phone
what is meant by rebooting the device turn off and turn it back on.
review of Add-ons visit Here link...
make sure enable roaming on,
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
for Re-Purchase Add-ons you need to wait 25 hours after the expiry first Purchase Add-ons or you need to Contact Customer Support Agent by CS_Agent, to them do it for you...
01-10-2022 06:31 PM - edited 01-10-2022 06:33 PM
By any chance, @jacob229 , are you asking this in conjunction with another user @fospeg ?
Are you both in the same predicament? Note their post in the thread just before this one.
You may require Public Mobile support if adding funds to reactivate isn't working for you; to contact a Customer Support Agent, there are 2 methods:
