08-18-2020 09:14 AM - edited 01-05-2022 12:35 PM
Hi,
I just switched my service to include international texting.
I can send a text to the USA and Germany but trying to send to Iran without success.
Any suggestions to resolve that would be appreciated.
Thanks
08-18-2020 11:27 AM
@asabet The fact that you can send out international texts to some and not to others suggests that the problem is on the other end provided you are dialing the number correctly.
08-18-2020 11:12 AM
Thanks a lot.
08-18-2020 11:06 AM
You try using an app like Textnow to see if the texts goes through.
08-18-2020 10:58 AM
@Anonymous oh, right, thanks. Yes, then the issue may be in country codes and how correctly to use them.
08-18-2020 10:57 AM
By the way, that is only for texting, not phone calls.
08-18-2020 10:54 AM
@asabet Its the exit codes. I misread your post. I thought you meant calling. Stay safe
08-18-2020 10:53 AM - edited 08-18-2020 11:00 AM
@asabet wrote:Hi,
Thanks
Yes @gblackma and @Staliger read the subject line. 🙂
@asabet : The recipient may have their own limitations on receiving international texts. Some countries may put up their own filters too on incoming communications from elsewhere.
Edit: as per the exit code thought...you could also try just the + symbol in front of all the numbers. Looking at the example in Triguy's excellent post...instead of the 011, use just +.
08-18-2020 10:51 AM
@asabet you can send messages only to countries listed in the addon. Iran is not one of them unfortunately.
08-18-2020 10:50 AM
That is not Addon.
That is a plan with "Unlimited International Text and Picture Messaging".
Nowhere has mentioned that Iran is not included.
08-18-2020 09:47 AM
@asabet Iran isn't included in the international addon. You have to get a calling card.Stay safe.
Intl long distance Add-On included countries: Canada, China, France, Germany, Greece, Hong Kong, India, Italy, South Korea, Malaysia, Mexico, Poland, Portugal, Puerto Rico, Singapore, Spain, Thailand, United Kingdom, United States, and Venezuela. Calls must originate from Canada.
08-18-2020 09:38 AM
Did you try a few different Iran numbers to text to? Maybe it might be an issue with the Iran mobile number.
08-18-2020 09:19 AM
