International Roaming
MrJLlC
HI. I'm traveling to a non-us country. Is there a way to have roaming, mostly for calls and text?
Thank you
2 REPLIES 2
Chalupa_Batman
Hello @MrJLlC
Public Mobile only works in Canada and the United States. The option I recommend is to purchase a SIM card through this service, Local and regional eSIMs for travellers - Airalo and then use an app called TextNow. You can pick a local number to where you live and use that to make calls and text messages back to Canada. Just update your Public Mobile voicemail to state you can be reached at this number for the next "enter time here... 2 weeks" via calls or texts. Good luck and enjoy your vacation.
hairbag1
@MrJLlC
PM service only works in Canada or US with an add-on or Canada / US plan.
added...you could download the free voip app such as TextNow. You'll be able to call and text most any US or Cdn number for free using your local wifi.
