05-18-2019 03:34 PM - edited 01-05-2022 05:00 AM
Hi, I am overseas now (in Europe) and I paid $15CAD for 400 min. International roaming (not for Canada and US only), but the service is not working out, by some reason. I extremely need that! My understanding is: the International Roaming and Canada/US Roaming - completely different services, provided by PM. So why my expensive ($15) International Roaming is not functioning then?
05-19-2019 05:11 AM
The only country Public Mobile works in , if a roaming plan is bought, is USA. Other than that Public Mobile only works in Canada. There are no other counties at present in which Public Mobile works .
05-18-2019 05:09 PM
@lialka wrote:l've already did that. They are keeping silence... I am waiting... But who would tell me what does it mean "International roaming" service, following after "Canada/US roaming"???
It doesn't say International Roaming it says Calling and it is a long distance plan for calls that originate in Canada
05-18-2019 04:53 PM
@lialka wrote:Hi, I am overseas now (in Europe) and I paid $15CAD for 400 min. International roaming (not for Canada and US only), but the service is not working out, by some reason. I extremely need that! My understanding is: the International Roaming and Canada/US Roaming - completely different services, provided by PM. So why my expensive ($15) International Roaming is not functioning then?
PM doesn't have international roaming, but only has US roaming plan. 400 minutes international talking is only for in Canada, but not for outside Canada. There's a line said in Canada above 400 minutes international talk.
05-18-2019 04:49 PM
@lialka the only option is what I wrote above.
More details here https://productioncommunity.publicmobile.ca/t5/Getting-Started/Traveling-to-Australia/m-p/164869/hig...
05-18-2019 04:43 PM
Nothing is possiible distantly. Other choice to get automated call from them with access code, but they cannot call to my number, as I told...
05-18-2019 04:43 PM
@lialka wrote:I need to keep my own number to have my online banking access, not for fun..
Then you need to:
1)get a friend in Canada to buy you a sim card
2) do a sim number change in self serve
3) have friend install sim in a old phone
4)set up call forwarding to your fongo number
5) install a sms forwarding app if you need sms
Alternately change your baking contact info to your fongo number.
Fongo provides a free Canadian number
05-18-2019 04:41 PM
Look at that.. it’s written US before roaming
05-18-2019 04:40 PM
I've already tried it. They provide with their phone #, but cannot keep my existing...
05-18-2019 04:38 PM
No, they send SMS to my registered phone number...
05-18-2019 04:37 PM
05-18-2019 04:35 PM
@lialka wrote:My TD bank send SMS for account access confirmation, and I cannot do that and don't know how to find a solution..
Reach your TD bank to ask another solution than SMS????
05-18-2019 04:34 PM
05-18-2019 04:34 PM
You can't have access with an app to your bank?
05-18-2019 04:34 PM
@lialka : Hi, I also want to point out that you could reach the moderators about this and maybe they can reimburse your international add-on;
Click this: message to moderators
05-18-2019 04:32 PM
05-18-2019 04:28 PM
@lialka even if public had international roaming it's usually cheaper to buy a local sim card when in europe.
If you need to receive calls from Canada I would get a fongo.com account and give that to your contacts. That would work on wifi or if you get data with a local sim
05-18-2019 03:55 PM - edited 05-18-2019 03:56 PM
@lialka The international add-on only works when you are in Canada so it definitely will not work when you are overseas. As previously mentioned your best choice it to purchase a prepaid sim locally. On the plus side the rates in many places overseas are much better that what we pay here so it might be more economical for you in the long run.
05-18-2019 03:41 PM
Sorry for you. But you can buy a sim card for few euros and a plan for 2 euros for 1 month...look at Free.fr. Or at gigsky.com. Enjoy your trip!
05-18-2019 03:38 PM
