6 hours ago
Hello,
I have 300 international long distance minutes but Public mobile won't let me make a call to the US, says I don't have minutes.
Please help.
Thanks,
6 hours ago
@hTideGnow thanks for your help! It's been a few weeks since I got it but I didn't know US was separate
6 hours ago
to ask PM to help to switch, Just open ticket with them using the Orange Chatbot icon on lower right, start typing Submit ticket, choose Contact Us and then follow the screen to login and submit ticket
6 hours ago
@slusagm Thanks for the help, thought that might be the case but wasn't sure! How do I ask to switch it?
6 hours ago
HI @Angjelin
to call US , you need the $15 - 1000 US Long Disstand minutes and not the 300 International one
if you just got it, ask support agent to help switch for you
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
or a free way to call US is to download the VoIP app TextNow to call US for free using the app
6 hours ago
you got the wrong addon, the International one is not for you to call US. There is a specific one to call US instead. you need to login to buy the correct one or ask PM to switch it for you
