01-10-2021 05:42 PM - edited 01-05-2022 04:48 PM
Do you know if the countries available in the International Calling Holiday Giveaway includes the UK? I know that the UK is not included in the list on the page where you purchase add-ons. However, I'm asking because I received 400 Holiday Giveaway international calling minutes a year ago. I have used 308 of those minutes calling the United Kingdom. The last call I made was maybe four or five months ago. I tried to call the UK today, and it doesn't work. My account shows that I still have used only 308 of the 400 minutes. So was the UK removed from the list recently?
I realize that I can purchase 1000 UK minutes for $15, which I may do, but I don't understand why it worked before, but not now.
01-11-2021 08:26 PM
That's similar to the the data add ons with the august 2019 data gift started then 2019's holiday data add on got started. I wonder if this years holiday data add on will get tapped?
01-11-2021 02:56 PM
Did you look to see if the newly used minutes are coming off the old 400 minute International add-on or the new 500 minute add-on? Since the new Give away add-on is an add-on that technically is no longer available I think it is identical to the old one as @Anonymous said so you should be good.
I used 2 of my 400 minutes in the summer to call the USA and then I used 1 more minute to the USA since receiving the recent gift and it was deducted from the new gift, not the old. I’m going to have these minutes sitting there forever at this rate!
AE_Collector
01-11-2021 02:18 PM
That is absolutely right. The PM long distance prices are far better than what they can do in Britain. So I always make the calls from this end.
01-11-2021 02:13 PM
I'm happy to hear it's been worked out. I happened to look at long distance calling rates to call Canada from the UK the other day and across the board they averaged a 5 min call=90 min call from a pm customer calling the UK. Calling your friend (or calling them back) saves them all small fortune !
3/3 days?
01-11-2021 04:58 AM
Well, I was finally able to get through to the cell phone number. I used the +44 method, which worked well; then part way through my conversation, the call got dropped, so I called back using the 011 44... method, and that worked too.
It turns out that the land line I was trying to call was malfunctioning and because of their lockdown they haven't been able to get a repairperson to come in.
Thank you to everyone who chipped in to help me with this. I had intended to credit both darlicious and jb456 with a solution, but discovered that it allows only one. I clicked jb456 first, and that was all it would let me do.
01-10-2021 11:50 PM
Thanks darlicious and jb456 for the suggestions about calling the London underground and holding the zero for the plus sign instead of using 011 (though I did try it first with 011,and it wouldn't connect "for security reasons"). But the +44 connected me to the underground, so obviously, the international minutes are working. So I will try the person's number again tomorrow. Not now because if it works they might not appreciate a call at 5:00 a.m.
It is strange, though, that I whenever I called before, I used 011 and it worked. I'll post what happens after I try it.
01-10-2021 11:04 PM
01-10-2021 10:01 PM - edited 01-10-2021 10:02 PM
@darlicious to many digits in your number. 0343. Should be just 343.
@Tirzin I call UK all the time. No need for 011.
Just +44 followed by 10 digit number. Not sure what phone you have but mine I hold down the 0 for a few seconds to get the + sign.
The number @darlicious just mentioned works as followed.
01-10-2021 09:51 PM
Try calling : 011 44 0343 222 1234 (London Underground Helpline) to see if it goes thru.
01-10-2021 09:29 PM - edited 01-10-2021 09:31 PM
If you wanted to enable roaming when travelling with most providers you dial 611 first then enter a code or if you require customer support while out of country you would dial 611 so these are automatic messages you are getting essentially from telus.....hmmm maybe you can call telus and ask them if theres an outage or an infastructure issue.
Edit: Have you tried a different number?
01-10-2021 08:15 PM
When I try the person's land line, I immediately get a message saying something like, "Your call cannot be completed to this number. Then it says to call *611 (which goes to Public Mobile automated service).
When I try the person's cell number it just rings for a very long time and then goes to the message that it can't connect to that number. I don't remember if it then recommends calling *611, though I don't think it does. I had not tried texting because the person cannot text back, so I can't tell if it got through. Anyway, thinking about it, I tried just now. There has been no indication that it didn't work, but, as said, there isn't really a way for me to know.
01-10-2021 06:58 PM - edited 01-10-2021 06:58 PM
When you call do you get an error message? Dead air? A constant double tone? Can you text the number?
01-10-2021 06:08 PM
@esjliv : what do you suppose United Kingdom shortens down to? (edited now 🙂 )
@Anonymous , i zigged when I should have zagged, went left when I should have went right.
Copy, paste, scanned, mis-read. Noticed after posted. Then noticed you had it all tidied up!
01-10-2021 05:45 PM - edited 01-10-2021 05:47 PM
@Tirzin : Yes. The original international 400 minutes did. Last years gifted 400 minutes did. This years gifted 500 minutes did. Are you calling the same number that you've got through from before? Is your service active?
Hello @Tirzin
I do not know about the one from 1 year ago.
@Anonymous got the others covered 🙂
01-10-2021 05:44 PM
Yes
