10-28-2024 09:30 PM
10-29-2024 12:28 AM
10-28-2024 09:38 PM
It depends on what you're trying to do with it. If you want data, phone calls or SMS while moving around then you will need to get a SIM from somewhere else with Indonesia service. If you just want to send RCS, iMessage or WhatsApp etc. then you can do that while connected to Wi-Fi.
10-28-2024 09:34 PM
you can't use roaming in Indonesia, no such option. PM only roams in US
if your phone supports, use Airalo eSIM for data and use Fongo app for voice call and text
10-28-2024 09:33 PM
@Evie01 Sorry PM only has roaming options in the USA , anywheres else I the world your best to get local pre paid SIM card in your destination
10-28-2024 09:32 PM
sorry @Evie01 , PM only has roaming in US and no other country. You need to use travel esim or local data sim
