10-28-2024
04:56 PM
10-28-2024
11:57 PM
computergeek541
I am not receiving text and unable to send text messages on Phone, but able to receive on my MacBook. What is the issue since my plan is up-to-date. N.Kwan
10-28-2024 11:27 PM
@NKwan wrote:Hi thanks again, I tried doing the reset you said to do but now I am just stuck with the phone number saying it is being verified and with a loading signal
I have deleted that picture from your message post. Please go into your Community delete that picture. This is a publicly viewable website.
10-28-2024 10:33 PM
It works now!!! Thank you so much for your help!!
10-28-2024 08:51 PM
@NKwan Did you try my last suggestion of shutting down phone thru the settings > general bottom of page “shut down” in blue letters . This is different from rebooting the phone or reseting network settings it will take the phone right of the servers and when you start the phone back up should blip back on and hopefully straighten itself out . Give it a try if you haven’t already . Look at my last reply for and follow the steps . If should work
10-28-2024
08:06 PM
10-28-2024
11:27 PM
computergeek541
10-28-2024 07:03 PM
hi @NKwan reboot the phone. Check iMessage is registered with your number or still blank. If blankz try Reset Network settings and then add the number again
10-28-2024 06:47 PM - edited 10-28-2024 06:48 PM
@NKwan Another thing you can try also is turn off iMessage again and face time then go to setting >genreal at the bottom of page you see “shut down “ in my pic
Then wait 2 mins power back on and turn on iMessage and face time .
10-28-2024 06:34 PM
@NKwan So strange , Do you have e eSIM or physical sim ? If physical sim can you test the SIM card in another phone ? If it works put it back on your phone and see if it clears things up . If all else fails you can ask support to refresh your account on their end
10-28-2024 06:30 PM
Hi thank you for teh tips I tried both of these but now I am unable to reconnect my number to iMessage. It just says waiting for activation and that the number is verifying. It has been like this for a while now
10-28-2024 05:14 PM
@NKwan try turning off iMessage and face time and turn phone off for 2-5 mins then turn phone back on and turn on iMessage and face time and reset network settings . See if that clear up the hiccup
10-28-2024 05:12 PM
Yes so when I send messages on my iPhone, they do not send and have that typical iPhone message that happens when you aren't connected to wifi even though I am. Then when I go on to my mac which is connected to the iPhone I can see messages that people have sent me that do no appear on my iPhone. I can send and receive iMessage on my Macbook but my iPhone does not show them even after rebooting the phone multiple times.
10-28-2024 05:12 PM
HI @NKwan
did it ever work? or it worked and just stop working?
try to disable iMessage, reboot and reenable
if same, go as far as remove the phone number on iMessage, reboot and put it back to re-register
10-28-2024 05:10 PM
I meant iMessages. Both mobile data and wifi don't work. Rebooting my phone also doesn't work but thank you for the advice!
10-28-2024 04:59 PM
you meant email or sms text? iMessage?
did you turn on Mobile Data? maybe try reboot phone
10-28-2024 04:59 PM
HI @NKwan
you meant you linked your phone with MacBook , and you see the text on MacBook but not iPhone? If it is, then the messages arrived on the iPhone already (if not, you won't see it on the Macbook)
