04-03-2022 12:10 PM
04-03-2022 09:25 PM
the AI is slightly slow .. you have half a minute to catch it before magician says Abracadabra
04-03-2022 09:22 PM
I think @14ALL41 was referring to how @JL9 saw your post @darlicious if it disappeared. Not how you retrieved it.
It must have first appeared, JL9 saw it, then got moved.
04-03-2022 03:56 PM
Search "*poof* the magic dragon...." that's how I find the link...lol....
04-03-2022 03:16 PM
@JL9 wrote:Yeah I second @darlicious, much cheaper and more efficient to go the calling card or voip route for those calls.
How did you see that lost post when it was removed?
04-03-2022 03:07 PM
@darlicious wrote:Omg that's two posts fallen victim to *poof* the magic dragon disappearing post bug....
Third time lucky?
Yes, you are. You did so much research, typing and poof, post is gone. I think you should start campaign 'Do not remove our posts you stupid AI'
04-03-2022 03:02 PM
Third time lucky?
04-03-2022 02:47 PM
And where do you see @darlicious post?????
04-03-2022 01:50 PM - edited 04-03-2022 01:51 PM
PM doesn’t have Indonesia for the International calling on the countries list.
300 International Long Distance Minutes
I would suggest you download the WhatsApp and use your PM cell number or use TextNow app and pick a new Canadian number.
04-03-2022 12:19 PM
