Incoming calls
10-23-2019 11:28 PM - edited 01-05-2022 07:43 AM
10-25-2019 03:12 AM
@kelvarnsen wrote:Are you somewhere where you actually have cell reception?
Outgoing calls wouldn't work if there's no reception. @Hiledgarciano would say if it wasn't only incoming.
10-24-2019 07:54 AM
10-24-2019 12:13 AM
@Hiledgarciano wrote:Why I can’t receive incoming calls? Thanks
If porting, use old carrier until it stops working so you don't miss people calling you.
10-23-2019 11:39 PM
Are you able to make outgoing call, text, ?
10-23-2019 11:30 PM
@Hiledgarciano Have you just activated and are porting in a number? That would mean your port is not complete yet. Otherwise try rebooting your phone. If that doesn't work tell us and well go from there.
10-23-2019 11:29 PM - edited 10-23-2019 11:33 PM
Which plan are you on? Does your text and data work? More details about your situation may be helpful. New customer versus old, etc.
Check your add on section to see if you see the talk minutes add on. If you don't see the talk add on, you might have used up your minutes. Then you can buy the $5 talk add on for 500 Cdn minutes (unused minutes roll over)
