New Public Mobile customer start up help
06-08-2019 12:50 PM - edited 01-05-2022 07:43 AM
Hello all. I would appreciate any input please. I just signed up and activated my phone.
The service is now running and I can make phone calls no problem. But text messages come in and dissapear when I go to look at them and when I go to send text messages they dissapear as well. Also my clock on my phone is 1.5hrs behind. Im within the first hour of activation. Will this all smooth out in a few hours? Thanks for your time and input!
Service
06-08-2019 01:12 PM
glad things worked for you @FrankRizzo welcome to Pm we got your back lol
06-08-2019 01:01 PM
Yes that worked ha! Thanks very much!
06-08-2019 01:00 PM
Thank you all guys! Much appreciated!
06-08-2019 01:00 PM - edited 06-08-2019 01:01 PM
06-08-2019 12:59 PM
Just solved my problem thanks for your input! Cheers!
06-08-2019 12:58 PM
@FrankRizzo wrote:Hello all. I would appreciate any input please. I just signed up and activated my phone.
@FrankRizzo Are you using a new phone previously owned? Sounds like you might have to do a reset. The time should dispay correctly from the start unless it's set to manual mode.
06-08-2019 12:56 PM
Ok I will try that as well, thank you!
06-08-2019 12:55 PM
@FrankRizzoTry set the time and timezone manually and see if the text issue would go away.
06-08-2019 12:54 PM
Ok I will try that. Thank you!
06-08-2019 12:53 PM
Windows Phone Lumia 435. It worked fine before. I just came from Telus.
Ive restarted a few times to see if that would help to no luck.
06-08-2019 12:53 PM - edited 06-08-2019 12:54 PM
It seems you need to go into your settings and auto sinc your date and time I know that screws things up on my phone
06-08-2019 12:52 PM - edited 06-08-2019 12:53 PM
@FrankRizzoIt sounds like it is a problem with your phone more than Public. What phone and model is it? Do you know if others can receive your text and they can send text to you without any errors??
