Ya roaming data add on
Chachie69
Can’t use it I’m in Canada Nd picked the wrong data add on
cellphoneuser1
Roaming add-on can't be used in Canada. Roaming does not mean travelling or visiting a different city. Roaming means connecting to a different network. Public Mobile network is Canada-wide. You will need to purchase the correct data add-on. For an adjustment, you will have to hope for goodwill gesture fromt a moderator.
hairbag1
You need the data add-on for use in Canada....1Gb for $30.
geopublic
@Chachie69
To submit a ticket to Public Mobile do the following: PMST.png
