11-18-2021 06:06 PM - edited 01-04-2022 05:09 AM
I have issue reseting my password because I can't remember my security question. Kindly assist
11-18-2021 06:28 PM - edited 11-18-2021 06:29 PM
@thayor If you cannot answer the security question, only PM Support can assist to reset the password.
If you have not opened the ticket yet, follow this to get to the ticket open page quicker
https://publicmobile.ca/chatbot
11-18-2021 06:13 PM - edited 11-18-2021 06:14 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
11-18-2021 06:08 PM
You'll need to contact the CSA's for assistance:
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar
