01-07-2025 03:31 PM
My son lost his phone and I can’t login to my account because the verification code goes to his lost phone. I need to cancel the subscription. Help please.
01-10-2025 12:04 PM
I did that and never received an email.
01-07-2025 03:42 PM
hi @Tydaisy77 if you know the voicemail pin, you can also get the code via voicemail . click Didn't receive code and select voicemail
what a minute and call yourself from another phone and enter # to enter voicemail check mode and enter PIN to get the code
01-07-2025 03:35 PM - edited 01-07-2025 03:39 PM
@Tydaisy77 Underneath where you enter the code should have something like "didn't receive code". Click on that and you should be able to have it sent to email.
Edit: barring the above you will need to contact customer service at the link below:
