If i go with public mobile can i use it in cornwall ontario canada
ryder1954
Can i use public mobile in cornwall ontario
10 REPLIES 10
Cyber
@ryder1954,
Public Mobile is owned by Telus. This is the same network as Telus.
Telus own the biggest network in Canada.
You can't find better !
Seems that ryder1954 is covered then.
Plus @ryder1954 there will an opportunity to opt into a 90 day plan. If you think you can get by with just 1 GB of data over 90 days your total cost for 90 days will be $90!
hunnybunny
Hi @ryder1954
 I am in brockville and have no problems here as well as traveled throw cornwall and over to ottawa and didnt lose a signal once 🙂 hope this helps.
Who, for $45
And what sort of Talk, Text, Data?
ryder1954
They have a good fair price for 45 dollars with talk text data for prepaid
Currently, in Man, and Sask, Both have THEIR Own Carrier Co.
MTS In Man, and Sasktel in Sask.
For Some reason, ONLY Telus and Koodo Postpaid have Access to all these provinces's areas
Telus, Koodo, Public Mobile Prepaid are only in Major City Areas
Not Ideal, nor Fair, Hopefully Telus will Rectify this so All Prepaids under Her can enjoy Thorough Coverage
There are actually some (remote) locations where a cell phone signal cannot be received. If you currently use a cell phone you should be ok. Also you can look at PM's National Coverage map under the tab "Why Public Mobile?".
That means, if a Cell Tower is in the area
NO TOWER, NO SERVICES
Are you looking for Canada-Wide? or Province-Wide?
ryder1954
What do you mean cellphone area
Luddite
Yes. Provincial plan covers all of the province where you register; Canada wide covers all of Canada. caveat on both is that you must be in a cell phone signal area.
