2 hours ago
Hello
Have $34.00 unlimited Canada/USA we crossed at Thousand Island Border crossing near Ottawa Ontario and entered the US. We followed the instructions we were given on this form and it has worked incredibly poorly. We are in Scranton Pennsylvania and it still is terrible.
Also why do we have an E by our battery charge symbol?
42m ago
True. I have 3 phones here in my posession now that are all VoLTE enabled. I plan on testing all three when in the US next month.
48m ago
@Chalupa_Batman True, but if it is on the list then it may not be a VoLTE problem, process of elimination.
an hour ago
@Phil_Adelphus wrote:@Hank6 Check if your phone is on this list or a newer version of one that is.
https://www.publicmobile.ca/en/on/get-help/articles/volte
Just to add to @Phil_Adelphus , there are several other phones out there that use VoLTE that work on PM but not on the list. It's more of a trial and error sometimes.
2 hours ago
2 hours ago
Hey @Hank6
Depending on your phone, try this. Go into your network settings, turn off automatic and pick T-Mobile. Then turn on your Data Roaming and then reboot. This should work.
If you need help figuring out how, let us know.
2 hours ago
@Hank6 , what phone are you using? The E indicates connection to T-Mobile 2G. Try rebooting your phone to see if you can connect to the LTE or 5G networks.
